WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
That's very possible. Maybe when you were pulling it was snagging on something. I would strip the new wire again at the splice and give it another shot. Possibly
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
NOT A HARD JOB.DRAIN OUT SOME OF YOUR COOLANT UNTIL BELOW THERMOSTAT.REMOVE RADIATOR SUPPORT COVER THEN REMOVE THE AIR FILTER HOUSING.THEN LOOSEN REMOVE HOSE CLAMP TO THERMOSTAT HOUSING.THEN REMOVE THERMOSTAT HOUSING AND THERMOSTAT.THEN INSTALL NEW THERMOSTAT WITH NEW O RING ON THERMOSTAT. LUBRICATE NEW O RING.BESURE INSTALL NEW THERMOSTAT WITH THE SPRING END ON THE INSIDE OF THE HOUSING.TORQUE THERMOSTAT HOUSING BOLTS TO 89 INCH POUNDS.
Remove thermostat and run the vehicle. do your hoses get tight now? If so, your new thermostat was not opening up. test it by putting it into a pot of water and bring up the temp on your stovetop. if the water boils, and the thermostat isnt open, then get a refund and a new thermostat. Be sure to point the spring end of the thermostat into the engine block when replacing. If your thermostat did open, then your water pump may be shot.
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
