Samsung HLP4663W 46" Rear Projection HDTV Logo
Posted on Oct 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung HLP4663W Color Wheel
What color wheel model number do I need. I get different answers on various web sites.
  • Anonymous Dec 10, 2007
    Step by step instructions and pictures for replacing the color wheel here:
    http://www.jangro.com/a/2006/07/24/samsu...
Anonymous
Level 2:
Novelist:
  • Expert 192 Answers
  • Posted on Oct 21, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
192
Questions
0
Helped
109433
Points
379
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 10, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2083
Points
Step by step instructions and pictures here:
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
A
Anonymous
The BP96-00674A replacement Color Wheels are not available from Samsung at this time. My understanding is that they are doing so much warranty work they can't release them for others. Sounds like a defective part to me and Samsung should replace free.
My t.v is making a buzzing noise When the colors wheel spins off it axis what is an axis
Sometimes the time the Color wheel,will shatter apart,this is a common problem with samsung the Color wheel be comes defective and needs to be replaced.
Encompass Parts Distribution 1-800-638-3328 Go to their website and type in your model number for List of Parts /Prices.
Samsung Parts 1-800-627-4368
3answers
High frequency noise
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
1helpful
2answers
Make a loud type of humming noise and the color is flickering in and out of color.
IF you are hearing a fan like noise it most likely is the color wheel that this model uses--set was first made in 2004
This model uses two different color wheels--depends on version number you will find on right side of set on a label with the model number.
The color wheel is just what it sounds like--a round plastic wheel with different colored segments that spins at about 12,000 + rpm---a lot of them fail after a few years---usually a fan like noise or grinding noise and sometimes the wheel will shatter and the set will shut down.
Once you ID the version number of your set there are sites on the internet that have video instructions for its replacement--takes less than 1 hour to do this.
If you cannot do it you will pay a fair amount as most shops like to get as much as they can for this easy repair.
LET ME KNOW IF YOU HAVE QUESTIONS
WITH THE FULL MODEL NUMBER AND VERSION NUMBER OF YOUR SET I CAN TELL YOU THE PART NUMBER FOR THE WHEEL.
I am here to help.
REGARDS, SD TECH
How do I access the color wheel on my Samsung HLP4663W?
Looking from the rear of the set, the color wheel is just to the left of the lamp, underneat an aluminum heat sink. You have to remove 7 screws to get to it.
Install color wheel in samsung hlp tv model #hlp4663w
yes u need to take the optical block out is hold by screw umplug the hdvi cable and 2 small cable caming from the anolog board , now take the top black cover wicht is protecting the color wheel now remove the only 2 screw for the color wheel , becare full when remove the 2 smaller cable for the color wheel and when put it in the color wheel back in place
About the color wheel option
Hello Brandon B,
look on the side of the unit there will be a sticker with Model number, serial number and Version code. The version code will tell me what color wheel you need. There maybe some CCA adjustment you need to do using the remote in Service mode. Let me know what the version number. We will go from there. You can contact www.interactiverepair.com they will walk you through the installation process
Best regards
circuitcity
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
2answers
1helpful
SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
2answers
Samsung lcd tv
You have a defective color wheel. Its not easy to change. You must be familiar with the Lite engine. This TV carries 2 types of Color wheel. Look at the side of the TV for your version number to see which one it uses.
(1) Part number BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
(2) Part number BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
CircuitCity
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
