LG 50PK550 50 HDTV Plasma TV Logo
M
Mark J Cady Jr Posted on Jan 08, 2014
Cannot adjust zoom
Zoom is stuck in zoom 1
  • mercedes obey
    mercedes obey Mar 20, 2014
    I am having this same problem. I unplugged the set for 15 minutes and it corrected itself for a little while, but then it zoomed in again.
mercedes obey
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2014
mercedes obey
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
405
Points
I just fixed this problem on my tv. it is not the tv it is the cable box. i changed it by pushing the aspect button on my cable remote.
Zoom adjustment wont move, chg battery and no help. help
  1. In many apps, you can zoom in or out on specific items. For example, you can double-tap or pinch to look closer in Photos or expand webpage columns in Safari. You can also use the Zoom feature to magnify the screen no matter what you're doing. You can magnify the entire screen (Full Screen Zoom) or magnify only part of the screen with a resizable lens (Window Zoom). And, you can use Zoom together with VoiceOver.
  1. Go to Settings > Accessibility > Zoom, then turn on Zoom.
  2. Adjust any of the following:
    • Follow Focus: Track your selections, the text insertion point, and your typing.
    • Smart Typing: Switch to Window Zoom when a keyboard appears.
    • Keyboard Shortcuts: Turn on keyboard shortcuts to control Zoom.
    • Zoom Controller: Turn the controller on, set controller actions, and adjust the color and opacity.
    • Zoom Region: Choose Full Screen Zoom or Window Zoom.
    • Zoom Filter: Choose None, Inverted, Grayscale, Grayscale Inverted, or Low Light.
    • Maximum Zoom Level: Drag the slider to adjust the level.
  3. If you use iPhone with a pointer device, you can also set the following below Pointer Control:
    • Zoom Pan: Choose Continuous, Centered, or Edges to set how the screen image moves with the pointer.
    • Adjust Size with Zoom: Allow the pointer to scale with zoom.
  4. To add Zoom to Accessibility Shortcut, go to Settings > Accessibility > Accessibility Shortcut, then tap Zoom.
  1. Double-tap the screen with three fingers or use accessibility shortcuts to turn on Zoom.
  2. To see more of the screen, do any of the following:
    • Adjust the magnification: Double-tap the screen with three fingers (without lifting your fingers after the second tap), then drag up or down. Or triple-tap with three fingers, then drag the Zoom Level slider.
    • Move the Zoom lens: (Window Zoom) Drag the handle at the bottom of the Zoom lens.
    • Pan to another area: (Full Screen Zoom) Drag the screen with three fingers.
  3. To adjust the settings with the Zoom menu, triple-tap with three fingers, then adjust any of the following:
    • Choose Region: Choose Full Screen Zoom or Window Zoom.
    • Resize Lens: (Window Zoom) Tap Resize Lens, then drag any of the round handles that appear.
    • Choose Filter: Choose Inverted, Grayscale, Grayscale Inverted, or Low Light.
    • Show Controller: Show the Zoom Controller.
  4. To use the Zoom Controller, do any of the following:
    • Show the Zoom menu: Tap the controller.
    • Zoom in or out: Double-tap the controller.
    • Pan: When zoomed in, drag the controller.
While using Zoom with Magic Keyboard, the screen image follows the insertion point, keeping it in the center of the display. See Use Magic Keyboard with iPhone.
To turn off Zoom, double-tap the screen with three fingers or use accessibility shortcuts.
Jul 29, 2018 • Cameras
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Adjust zoom of monitor
mcdevito75 here, You can try going into Menu on the monitor or you can press the auto on your monitor to retrn to factory settings.
2helpful
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
1helpful
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Quantaray 28-90 for Nikon N65 zoom ring locked up
There is no secret locking switch. If a little gentle jiggling doesn't free the zoom ring, then I can only suggest you take it in to a reputable camera shop for a Clean-Lubricate-Adjust (CLA).
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
