I started a self cleaning cycle of 3 hrs and about 1h20 into it it started beeping continuously with the code EO 21. What's up with that. I could not eeven stop it. I had to shut off the breaker and even after turning on the power it kept beeping. Now the barker is off and I'm trying to figure this out.
Firstly you need to unplug and need to check the pump is not blocked. Take the machine to a rear yard or area where you can drain the water from the machine as there will be a few gallons inside it.
The pump may have a filter unit on the front bottom of the machine or hidden at the rear behind the panel . There will be a lot of water still in the machine which ever filter you need to remove.
Sounds as if its blocked with socks , underwire Bra money etc a DRAINAGE FAULT F21
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
SOURCE: EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
SOURCE: Jenn air range model SCE30600B error code FC
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
