Hidden switch, PN 8318084 on Maytag Mod. MTW5821TWO. Access for replacement or repair. I'm having trouble getting to the switch, no directions.
Check your filter screens in the inlet connections. I had tons of sediment in mine. Also if you have a compound shutoff valve(with the lever in the middle), they can get clogged. Id recommend starting at the inlet hoses and verifying you have pressure getting inside the washer. If the hoses have good pressure, then check the screens inside the threaded part on the back. If they are clean, then you may have a valve or controller problem, but losing both valves at the same time seems weird. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
These folks above have lots more info. Im a big fan of repair clinic.
Testimonial: "Yes I will go at the screens. I was just thinking, if I could take it out and apart, I could get it working or replace it"
