Need a manual for B22CS80SNS Model Filter needs replacing. Cannot find manual.
SOURCE: Need a manual on my refrigerator
That model uses the 9030 style filter at Sears. To remove the old filter push ******* the button next to the filter until it pops out a little then just pull it out, remove the cap and place it on the new filter. Make sure you remove the red seals from the end of the filter.
SOURCE: I need a manual in order to change out the water
Just found a similar manual for your fridge, hopefully this link will help at OwnersIQ
Best of luck
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202308045.pdf
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset
light. (This light will tell you when to replace the
water filter.)
press the button to the right of water filter to release filter...
SOURCE: Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
SOURCE: we never received a manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
