Question about Toshiba satellite c660
Black screen when i power on my laptop theres no display only black screen but the power led is ok.how to fix it
    Habit-Forming:
  • 23 Answers
Have you tried plugging in an external monitor to the graphics port?
This would get you going again and would help reduce the possibilities of what is wrong.
Posted on May 21, 2014
2 Suggested Answers
6ya staff
SOURCE:
tommya300
tommya300
  • 724 Answers
SOURCE: when i open my laptop only Q DISPLAY IN SCREEN HANG UP
Does the hard drive sound like it is spinning.
Did you try to go into the Bios setup?
Posted on Jul 27, 2009
The acer 5536 wireless lan communication button indicator isn't on and the screen is black.
try external monitor to laptop with screen disconnected ,if it works laptop ok screen has problem ,common problem blown fluro light or power to screen and power to fluro ok fluro has problem,check power to screen fluro nil then screen power supply problem or led check wire loom from case to screen power supply.
Sep 08, 2014 | Acer ASPIRE 5536-5883 COMPATIBLE LAPTOP...
My laptop Lenovo g400.when I turn on my laptop its functioning but after 3 hours or less iturn off my laptop but when I I turn on again there is no screen display its all black but the power led is and...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 09, 2013 | Lenovo 3000 Computers & Internet
Cq60-212ea screen black power switch on power led on .processor fan on .but not laptop on screen black. Not display show. And not wellcome display show
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- https://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 14, 2011 | Compaq Computers & Internet
No display
This problem coming due to problem in RAM .replace it with new one.
Apr 06, 2009 | Acer Aspire 5100 Notebook
Black screen with no light on my compaq presario m2000
you need to provide more details.
pls check the adapter is good or not
check power socket
if power and adaptor is good then the numlock key leds and wireless and power key led must be green make sure it and if they are all green your screen may be bad check with another built in display card on the laptop to another monitor.
thanks
Mar 26, 2009 | Compaq Presario M2000 Notebook
Inspiron E 1405 laptop won't turn off and displays black screen
If it turns black again, try to check first if it's just the LED's that are defective. If you push the monitor 40 degrees down, and you can see very faint display from that angle, then it's probably that the LED's are the culprit, and you can have it replaced for a less price.
Jan 12, 2009 | Dell Inspiron E1405 Notebook
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Toshiba satellite c660 Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
