The motor seems fine, since the food processor works fine and it spins with nothing on it. It looks like the axle on the blender is stuck. I tried WD40 on it, but that didn't help. It's 7 years old.
SOURCE: Blender Dead as a Doornail
open unit wil find thermal fuse replace.alternative the lid that covers bowl normally turns cliickinto position .this activates aswitch check if properly locked in
SOURCE: grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
SOURCE: instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
SOURCE: When I turn on my cuisinart food processor, the
Either locked motor or bad brushes in the motor.
SOURCE: I have a DC 8 (DLC 8) Cuisinart Food Processor, 15
Your Cuisinart should be warrantied for a little longer (25 minus 15 years) so call the factory to authorize a return or see if you can drop it off at a local retail outlet to save you shipping costs (CA law requires them to accept it for service)..
New ones are only warrantied for 3 years and they cost about $200 on up.
I think your best investment is to get it fixed.
