After inserting the battery, my curve 8520 red light lights for a short while then the phone goes to a white screen with a small black clock-like face in the middle. Nothing further happens. Help will be greatly appreciated.
Good chance the unit is either broken and not allowing the Operating System (OS) to run. Next step would be to download/install Blackberry Desktop Manager (for this version of Blackberry) from the Blackberry website. Connect the Blackberry to the PC running Desktop Manager and see if the Desktop Manager can connect to the Blackberry. If yes, you could try to update the OS.
SOURCE: chocolate cell phone freezes when start up
same thing happened to mine and they are making me pay for a new one and its my 4th chocolate they werent holding the charge, the charging port wouldnt hold the charger, and the phone would lock up so i would have to take out the battery and put it back in
SOURCE: Blackberry storm has random resets
Remove suspicious apps one by one. If the problem remains after removing all apps restore the firmware to factory using the desktop manager. If the problem still remains there may be a hardware issue. If you're out of warranty there are Blackberry Repair Guides if you want to attempt a DIY repair, logic boards are on ebay.
SOURCE: Blackberry curve 8900, red light
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
SOURCE: blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
SOURCE: My blackberry curve 8520 loading
my blackberry curve a red light comes on then it only loads half way then crashes what will a do
