Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Loud popping on jvc av56wp74
No picture and loud popping noise, the noise goes away after about 20 -30 seconds and still no picture, can not use remote and the tv will not turn off with the button. the blue light continously flashes.
    President:
  • JVC Master
  • 1,348 Answers
If the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
Posted on May 23, 2009
6ya staff
SOURCE:
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
There is no red in picture on model number av56wp74 jvc rear projection tv what's wrong with it?
Ur CRT red gun is dead.Must hire the repairman for this job.It require part is hard to find,and alot of work and electronics skills to do this job.
Mar 17, 2010 | JVC AV-56WP74 56" Rear Projection...
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
What is really wrong with a jvc television? I heard the light bulb goes out ever three months, is that true? Barb
the AV56WP74 is a three CRT rear projection which has CRTs ( Picture Tubes) It doesnt have lamps or Bulbs
Apr 02, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC av56wp74 IC CHIP
you can get the replacement STK392-110 Ics and the JVC convergence resistor kit #1 at the following link which has the complete step by step instructions with pictures so you can easially do it yourself. You will need the resistors also as JVC will definately blow one or two resistors minimum when the Ics fail. Heres the link.
http://servicemanuals.vstore.ca/
Feb 01, 2009 | Televison & Video
Sounds like a jet taking off
the horizontal output transistor is busted or a protect diode,check the plyback maybe it has a leak
Oct 15, 2008 | Samsung HL-P6163W 61" TV
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
447 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
