Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
