Epson PictureMate Photo Printer Logo
A
Anonymous Posted on Jan 04, 2014
DOES NOT RECOGNIZESANDISK EXTREME - Epson PictureMate Photo Printer
1helpful
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Where can i get free drivers my wingman 3d extreme
Here: http://www.bioticaindia.com/wingman-extreme-digital-3d.html
Although a lot of people seem to have problems with it.
2answers
Faster processor for Striker Extreme board
Pentium Extreme ED-965(3.73GHz, rev C1) is as high as you can go.
http://uk.asus.com/product.aspx?P_ID=G7JoxzAEXsQwDt7G There is the full CPU support list for this Mobo.
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
Airport extreme
Try this in this order:
  1. Verify your aux on the DE675 is working with another analog audio source.
  2. Unplug the G5 -> optical -> DE675 and try playing itunes through the Extreme only into the DE675's aux.
  3. Optical digital audio output on the Mac is VERY fussy, so I'd stay off of the optical unless it's absolutely necessary.
  4. If you're finding that the Extreme is not putting out any sound at all, try this: Reset and update the firmware on the Extreme. Also, make sure your Mac is very updated with the latest iTunes, operating system updates, etc.
Where can i download the AirPort Extreme wireless networking
Dear,
Kindly find the AirPort Extreme driver at this location.
Regards,
Have a good day.
W.
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
EXTREME 6
I have a Royal Extreme 6. It does not use a USB port. The only way to connect it to the PC is through a serial port.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
