Kenmore HE2 Plus Front Load Washer Logo
A
Anonymous Posted on Jan 04, 2014
Striker got struck in lack and broke off how to i get it out of latch
David Payne
Level 3:
Top Expert:
  • Kenmore Master 14,162 Answers
  • Posted on Jun 16, 2015
David Payne
Kenmore Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2994907
Points
455836
2005 Chrysler PT Cruiser. How to be opening a struck hood, latch is struck.
'struck' you mean something banged it? or more likely 'stuck', won't move?
My hood cable broke on my pt cruiser, how can i open it?
JustAnswer https://www.justanswer.com > Chrysler Repair
Feb 23, 2012 - Best way then is to remove the plastic coating around the cable. May have to go back 10 inches to find the cable but you will find it where ...
Chrysler PT Cruiser Hood Latch (Lower) - 55255451AC
courtesychrysler.com https://parts.courtesychrysler.com > Hood-Latch-Lower
Latch. A Latch that secures the hood to the vehicle body when shut. Catch. Hood. Lock. Reinforcement. Hood Latch. Fits PT Cruiser (2001 - 2010)
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 70px;"> Rating: 4.9 · ‎ 73 reviews
Chrysler PT Cruiser Hood Latch Kit
AutoZone https://www.autozone.com > chrysler > pt-cruiser
Order Chrysler PT Cruiser Hood Latch Kit online today. Free Same Day Store Pickup. Check out free battery charging and engine diagnostic testing while you ...
Hood release handle broke in my 2005 saturn ion how do i get to the cable in the plastic part where the latch broke to grab the cable
Confusing post if your talking about the handle that you pull inside the passenger compartment then unbolt the bracket that it's attached to and you will see the cable ///if you Mean the hood latch safety tab that you lift or move to the side to open the hood after cable release you must disconnect the lock latch or the hood striker that it locks onto and raise the hood this can be done by removing the the front grille panel or by coming in from under the vehicle to unbolt the lock latch assembly from the radiator support
Is there any was to lower chime volume on strausbourg manor mantel clock Quartz Westminister chime
The only way to decrease the volume of a struck bell or metal coil is to dampen it by sticking (gluing or taping) something soft on it to absorb some of the striker energy input. Adding a soft substance where to striker contacts the bell will temporarily dampen or even silence the sound. How long this lasts depends on durability of the soft substance. RTV is an excellent material to use being sure to allow it to cure overnight before being struck.
Jun 13, 2019 • Chime Home
How to open the hood on 05 mitsubishi lancer es after hood release cable broke on engine bay side.
Cut the outer hood release cable sheath (under the dash) back to expose the inner wire cable, then using a pair of locking pliers (Vise Grips) pull on the inner release cable while another person pushes down over the latch area of the hood to relieve pressure on the latch and make it easier to open, the hook is released lubricate the hood latch and hood latch striker with white Lithium Grease (AKA "Lubriplate")
I have a 2004 Chevy Cavalier. I had no problems with the trunk when I bought it in February. It eventually got to the point that I would have to slam it hard to get it to latch. Now it won't latch at...
I do believe the latch is NOT adjustable while the striker which the latch closes onto has adjustment to it. Not the part on the trunk lid but the part in the trunk, it should have two bolts and when loosened the striker should move around. May or may not be enough for what you need but should have something.
hope this helps
1989 s10 blazer the door handle broke off we went threw the window to unlock the door. We lost the small spring that unlatches the door from the frame. I got the door finally open with a screw driver....
the interior trim will come off to gain access to the lost part. Get a telescopic magnet which will retreive this part. If it is the striker the latch hits and keeps the door safley shut That is what I think your refering to. The striker bolts to the B pillar which keeps the door shut. Also the striker should cost no more than $15 to 20 $$ to replace. Maybe less
My trunk wont shut on my 1991 buick park ave. Is the bottom part of the latch supossed to be at an angle?
CHECK FOR LOOSE BOLTS AT THE LATCH STRIKER IF BOLTS LOOSE MOVE STRIKER TO CORRECT POSITION SLOWLY CLOSE TRUNK LID UNTIL THE TRUNK LID LATCH AND LATCH STRIKER COME IN CONTACT TO CLOSE TRUNK.ONCE BOTH ADJUSTMENTS CORRECT. TIGHTEN THE LATCH STRIKER BOLTS TRUNK SHOULD NOW CLOSE.
2005 Suburban tail gate latch
at the latch see if you can maually open and close if you can you may need to adjust striker on the rear floor it may have been moved causing it too hit the outside of the latch
2002 FORD Explorer J that keeps the door shut broke
Are you sure the latch broke? sometime they can freeze up and hang unlatched. The part that latches the door to the striker is "C" shaped. If it is flipped into the latched position with the door open, it won't work. If this is the case, use a screwdriver and pry the latch to the open position while pulling the handle. But if it is broken, yes it can be replaced. Usually torx or allen screws in the end of the door. Pull the door panel off and pop the rods off before you unbolt it though!
Alexander
vince
