Pressed the back button and the power button. Coby flashes once then comes on and stays on. I don't think it is powering off at all I believe it goes into the standby mode which is preventing me from getting into the master file in order to do a factory reset. 1 how do I power off and two how do I get into the master file in order to do a factory reset?
SOURCE: Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
SOURCE: need bios password for fujitsu siemens v2055
bios password can only b reset by removing the c-mos battery...Try to goto boot in last known good configuration option in safemode....if it doesn't boot den install a new os..
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It
came time to part with my review unit of the G1 (Thanks T-Mobile!) and
send the phone back to its rightful owner. But what about all the
personal info on the phone? The apps, texts, e-mails, AIMs and all that
jazz? A quick search of AndroidForums.com turned up an easy way of
restoring your G1 to factory settings:
if you power
off your phone and hold the home (shaped like a house) and the end (red
hangup button) for about 20 seconds you get a triangle with an
exclamation point and a picture of the G1.
Now all
you have to do is pop open that pretty QWERTY keyboard and there are
several keyboard shortcuts you can use to accomplish what you want to
do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory
settings. I'm sure the soft reboot could be helpful too, should you run
into problems a troubled application may have caused. We didn't try the
other 2 options so use at your own risk.
By the way, I couldn't
live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile
service plan. I'm still a loyal Verizon customer and will simply have to
keep both plans... but I NEEDED the G1. So basically, you can expect the
application reviews and insight you've gotten at phandroid.com to
cotinue since we've got our very own device now!
[Via Android Forums]
SOURCE: coby 7015a will not do
I don't personally have one, but while looking for a different answer on a forum they said holding the power and 'home' buttons down at the same time would make it reset.
SOURCE: I own a Coby Mid8024
Since you have tried to reset and upgrade the system, yet the problem
still persist, the best option is to return it back to the dealer since
your warranty is still valid.
Contact the manufacturer of your Tablet PC to schedule service. If the
problem with your Tablet PC is related to the hardware, you may not have
the tools or knowledge needed to repair it. Trying to repair your
Tablet PC yourself could also void your warranty. Best best is to send it back to the dealer for replacement.
