My turn signals turn on ok but won't turn off after the turn is made, I have to manually turn them off. is this a fuse problem or could it be something else
Won't turn over? Do you mean the starter won't crank the engine over?
Or the engine cranks over and won't start, and you have tested for spark when cranking and have no spark? And then you have tested the coil and ignition module, and they tested out good? Am I on the right page here? If so, maybe the next thing to check would be the crank position sensor. The ecu (computer) signals the ignitor (ignition module) when to initiate spark after it digests the signals from the crank position sensor and the cam position sensor.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Not sure, but I've heard a bad hazard switch can cause strange problems. Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
YOU HAVE TO REPLACE THE TURN SIGNAL SWITCH.BECAUSE WHEN IT GOES OUT.SOME TIMES YOUR DIMMER SWITCH STOP WORKING.IF YOU GOING TO FIX IT YOUR SELF BESURE TO.DISARM AIR BAGS FIRST.
