The left door on the fridge requires us to push hard to close--it doesn't close on its own. The left side has the "flap" that must go between the two doors when shut. We are wondering if there is some adjustment that needs to be made. Any ideas?
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
SOURCE: freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
SOURCE: French door refrig..right door pops open when left door is closed
remove the door and check the closer inside the door @ the bottom . it is a cam that helps close the door and it is probably broken part # 67002732. this was the problem with my maytag fridge-- 3 visits from A& E could not solve the problem. hope this helps
