Question about Music
I have a MG50FX and almosto every time I play, I can play for about two or three minutes, then the sound gradually faints. after a while of playing on and off with the power switch, it comes to life again....for another two or theree minutes...ando so onWhat can I do?
    Top Expert:
  • Music Master
  • 3,156 Answers
You need to take it into the shop for internal repair. Don't attempt to do it yourself for fear of shock.
Posted on May 28, 2018
4 Suggested Answers
Anonymous
SOURCE:
user262
SOURCE: Marshall MB4410 - Dies and comes back to life every few minutes..
Our bassplayer had the same problem with his mb4410. As it turned out, the fan was not working when the amp got hot. It did turn when cold - go figure! Swap the fan for a good quality (Pabst, Sunon) 80mm pc fan with 2-wire connection. Three or four wire fans will not work w/out modding. See your local pc guy and ask for an unregulated, silent 24/7 fans. He will know. Our bassplayer sold the P.O.S. while still in warranty. HTH.
Posted on Sep 07, 2010
Testimonial: "Thanks for the reply."
Fred Yearian
  • 5603 Answers
SOURCE: FM 65R plays and sounds
Also the volume will probably be lower going into the line level PA input... If the amp is shutting down for thermal reasons, driving it less might not get to the point of shutdown. The schematic shows a temp sensor that reduces and shuts down the amp if the heatsinks get to hot. Possibly you are driving the amp harder than it is intended, If it is as loud (I doubt it) driving the PA input, then I would expect it to shutdown, but you would probably have to drive it harder than your guitar because guitar levels are well below line level. The amp claims 65 watts... don't believe everything you read in spec sheets... You should be able to generate 100 Db of sound with it... The more distortion you use will drive the amp harder and heat the heatsinks faster.
Posted on May 13, 2011
markmayes66
mark mayes
  • 786 Answers
SOURCE: Fender power chorus .
Sounds like a resister is bad..
Posted on Aug 16, 2012
I have three keys getting malfunctioned /cords not changing in left side, on split board.can this be fixed?
If those keys work normally, it's hard to see how the key switches themselves can be bad.
Is your keyboard MIDI capable? If you play the same chords, does the MIDI output look OK?
Could it be that your keyboard simply can't play all of the different sounds at the same time? I know some are limited in how many simultaneous tones can be played.
Jun 09, 2015 | Music
Today I received my new Privia px830 and three keys works as an interruptor: play notes at full intensity. Are sensors cracked?
The sensors are rubber, and don't usually crack. Most of the time they are dirty and can be cleaned with rubbing alcohol and Q-tips VERY carefully. Also be careful of the ribbon wires inside the keyboard. The keys should just snap in and out. I cleaned mine a little while ago, and now it works perfectly.
Jan 06, 2013 | Casio PX-830 BK Privia
I have an MG50FX amplifier that is less than half a year old and in the middle of playing the distortion will fade to the point of disappearing and will then suddenly come back in the middle of a note. ...
Many things can cause this... A COMMON problem is broken solder joints near potentiometer where they attach to the circuit board. Look for bad solder joints and also cracks in the circuit board.
Apr 04, 2011 | Marshall Amplification Marshall MG50FX 50...
While the Mackie Onyx 1220i unit is plugged into my computer I can port the sound through to my headphones via the headphone jack on the console. When I listen to sound play for about 2 minutes I'll...
OK... first thing is to DUMP ALL anti-virus and Anti_spyware and real time defragging programs as these resource hogs **** processing away from teh sound generation. Also is you are recording at the same time, if your disk is fragmented requiring a lot of head movement to record the time lags can cause buffer underruns and break up of audio... and eventually having the audio program "crashing" due to lack of throughput.
When doing audio work suspend all the resource hogs like the above mentioned programs. It is a good idea when recording CD's as well.
Feb 10, 2011 | Mackie Onyx 1220i Onyx1220i Onyx-1220-i...
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
Jan 17, 2011 | Yamaha Full-Size Keyboard
I just purchased an Alesis QS7 on eBay. Upon receiving
The unit needs to be repaired. Since it is a thermal problem, you can likely find the bad part with circuit cooler. See if the volume control affects the loudness of the howl... If it does, probably an op-amp in the preamp before the volume control is sick. If it doesn't affect it, then the output amps are suspect. Also check the power adapter.
Mar 03, 2010 | Alesis Music
The BOSS FDR-1 produces a popping sound when played
This is a common problem with this pedal experienced by allot of people. My best advice would be to sell it and put the money toward a real Fender tube amp and some good pickups. If you're trying to go cheap check out some Line 6 modeling stuff.
Oct 08, 2009 | Boss Music
MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
May 05, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
