SOURCE: car starts then stalls immediately
take the alternator off and have it tested at the auto parts store, this is more than likely your problem....
if it is good, then you need ot check your fuel injectors....
SOURCE: 89 Camaro RS starting issues post starter and battery fix
i would try checking my ground cables.try looking up the codes.this can be done for free at the local autozone or someplace like them.
i would also check the alternator/voltage regulator and there grounds.
SOURCE: gas not getting to engine
sounds like your fuel pump, normally fuel pumps die gradually not just like that, so best check fule pump fuses first, also i can not remeber if these have a fuel cut off switch, this is normally located arround the fire wall it looks like a red or black rubber button, if you have one you can press that and see if that sorts it, if not then it more than likley is the fuel pump and will possibly need replacing, but check the other things first, better a new fuse than a new pump...hope that helps a bit
Dead cell and or loose grounds at the starter will do it every time!!
