Everything in the refrigerator freezes
SOURCE: Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
SOURCE: frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
SOURCE: refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
SOURCE: refrigerator not cold, freezer not freezing.
the compressor is probably not running. most always it is the compressor relay 90% of the time. it is the plastic looking device that the wires are attached to on the compressor. this should be under a plastic cover attached to the compressor.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
problems.
Refrigerator
heatman101
problems.
Refrigerator
heatman101
