Check for fuse in the stop solenoid circuit
assuming it is a diesel engine that would be one thing to cause a sudden stop next would be a fuel air leak
if is a disaster to use easy start in a diesel as they have been known on many occasions to blow the piston through the sump, break cranks or blow the heads off
The reason is simple
diesels compress the air to white heat and then inject fuel at around 15 degrees btdc
by spraying in easy start which is highly volatile , it will self ignite around 95 degrees BTDC as it makes the compressing air highly explosive
SOURCE: Case 580C model 33 backhoe - transmission problems
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
good time to go ahead and change fluid,dexron 3 and clean screen filter.holds 8 quarts..check ur manual for correct installation of fluid. 3 quts.strt engine 5 more in filler tube
