SanDisk Sansa Fuze MP3 Player Logo
Posted on May 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pc does not recognize the divice...can't install the rhapsody cd it came with..Do I have to install this cd to be able to put music in it? Or can I use any other program?
I have a sanza fuze 2gb...the fm radio works fine but I can't get to put anymusic at all...my pc does not reconize the divice...and I can't install the cd that came with the player.
Anonymous
Level 2:
  • Expert 107 Answers
  • Posted on May 08, 2010
Anonymous
Expert
Level 2:
Answers
107
Questions
0
Helped
45520
Points
281
Try a rest = Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
23helpful
5answers
How do i put music into samsung freeform
firt if u have a usb cord,connect it 2 ur pc.in ur pc it will show new device found. then go in my computer,ther u'll find ur divice. click on it.now mininize it. go to ur music folder and copy and paste it in ur new device which u had mininized.ok
tip
How to remove DRM from Rhapsody, Amazon Unbox
"I am thinking about subscribing to rhapsody because they have unlimited downloads for a monthly payment. Then I found that those music and videos are DRM protected so they wont work with my ipod. But can I remove DRM from Rhapsody? If it is ok what is the best DRM remover/converter?"
Also, Amazon Unbox, which was rebranded as "Amazon Video on Demand", only play in desktop applications that support Windows Media DRM, thereby excluding devices such as iPod or Zune. Then, how to remove DRM from Amazon Unbox files and enjoy them on other player?
Have you met situations like these? If yes, here is a detailed tutorial about removing DRM from online music provider, such as Rhapsody and Amazon Unbox.
To remove drm from Rhapsody, Amazon Unbox, the methods of removing Rhapsody DRM listed below:
1: Remove DRM from Rhapsody, Amazon Unbox for free.
CD burning and ripping
First, insert a CD-R or CD-RW disc into your drive, and burn your playlist onto the CD. Then have the other media player import the songs off the CD and save them . When the music is imported off the CD, they are no longer DRM protected.
It is the most commonly known method. But it is costly (waste CDs) and time consuming, especially when you have a lot of music.
2: Remove DRM from Rhapsody, Amazon Unbox using Wondershare Media converter.
Using software to remove DRM from Rhapsody is much easier and quicker.As far as I know, wondershare media converter was one kind of this. After giving a test for some free trials I found it is a good Rhapsody DRM removal software with high output quality, professional, and easy of use.
To remove DRM from Rhapsody, Amazon Unbox , what you need to is just the 3 easy steps:
1. add DRM protected music and video to it. You can preview your files by double-click it.
2. Choose output format. You can reset the output path too.
3. After that, the only thing you need to operate is just click the start button, and the converting process is starting. After converting, the files are DRM-ripped.
After you get the output music and video files converted from the Rhapsody or Amazon Unbox playlist, you can now begin to transfer the files to your iPod, iPhone, Zune, etc.
Download Wondershare Media Converter for Free
on Jan 12, 2010 • Computers & Internet
3helpful
2answers
I lost my cd and need to reinstall the driver and software
Sorry but there are no specific drivers on the CD for this player. I've had this player since '05 and was trying to get it installed under Windows Vista with only limited success. This player seems to work best with Win XP.
The c150 has two modes of operation MSC and MTP. In MSC mode Windows recognizes the player as a flash drive. You create folders using Windows Explorer just like you do on any hard drive and then copy your music files into the folders. The second mode (MTP) works with a music player such as Rhapsody or Windows Media Player (ver. 10 or higher). SanDisk bundled Rhapsody on their CD and I just installed it (today) on my Vista PC and it seems to work OK. Any files dropped on the player in MTP mode are invisible to the music player running in MSC mode. However, all files added to the player, regardless of the mode used, are visible as one big happy list when you use the player.
You set the mode you want to use before plugging the player into a USB port by going to "menu/settings/USB" on the player then choose either MSC or Auto Detect (defaults to MTP).
SanDisk has very little tech support info about this player on it's web site. I hope this is helpful.
1helpful
2answers
Sansa 2GB lost my cd and I want to download new music
Hi
you have to download the driver that will allow your device to sync with your pc
here is the link to download the driver
http://www.sandisk.com/DriverDownload/index.asp
Download the driver
install it
and connect your sansa mp3 player
you should be able to add songs
Good luck
2answers
How to put music on lg voyagr
Use uitunes if you have it and drag sonds you want to a new folder on the desktop. Then used the MIcro SD Memory card to load songs and then put the card back in your phone to add to your "MY Music" section. When you save songs to your cartd save in the "MY Music" folder. not "PIX" or FLIX" ort anything else!
1helpful
How do i convert my rhapsody music files to play on my mp3
You have to get Rhapsody's Mp3 only service - I repeat, MP3 ONLY. No other level of Rhapsody service will work with the newer Philips' GoGear's - which is funny, b/c Philips co-branded with Rhapsody on the newer players.
-Tha Mp3 Doctor
How do I transfer music into the MP3 Player from rhapsody list?
First, read your manual.
Second, find the name of the folder that the Rhapsody songs are stored in, and copy them or move them to the "My Music" folder on your computer. If you are handy with computers, instead of moving the Rhapsody songs to the My Music folder, go into Windows Media Player instead - click the arrow underneath the Library tab, and select "More Options" --> Library --> Monitor Folders --> Add the Rhapsody folder to your list of folders.
Third, make sure you have Windows Media Player installed on your computer, since that is the program you will be using to transfer the songs. Click on the Library tab, and make sure that the songs show up on your computer. Once you see them, click on the Sync tab and start dragging the songs (no more than 10 songs in one sitting) to the window that says "Drag files here to synchronize..."). Click Start Sync.
Warning: Some GoGear models recognize Rhapsody songs and others do not. If you have Rhapsody's Mp3-Only service, then you are in the clear no matter what model of GoGear you have. If you have one of Rhapsody's other subscriptions, you may be in trouble. If your Go Gear is truly an SA6045, it will recognize DRM-protected Rhapsody songs, so you will be OK. If you have an SA3025 or one of the newer models, you will only be able to successfully transfer songs by signing up for Rhapsody's Mp3-Only service.
-Tha Mp3 Doctor
Insignia NS-8V24 Rhapsody problem
burn the music you PAID for to a cd then rip it back to the system and use Windows Media Player 11 to sync the files to the device (only works if you have a burn feature in rhapsody)
Windows Media Player will see it all the time and is more compatible then Rhapsody with the device
4answers
SANSA
My computer not recognise sansaclip
Sansa turns on but does NOT do anything!!! :0!!
Sounds like you have a few different problems, thankfully its easy to resolve. Run the recovery tool from the SanDisk website, select FORMAT when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck. (this only works with non Rhapsody devices, annotated by an 'R' or the word Rhapsody on back)
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
