Contact their customer service directly or use their website to reset or request a new password. Check their website for a email address and email them if noting else helps.
los www.howtosimplified.com1Turn del cortacircuitos cambian para la l?mpara en la caja de recorrido principal. Encienda el abanico y de varias veces para asegurar que no hay ning?n poder con el abanico 2Unscrew el alojamiento de techo del viejo abanico y diapositiva ello abajo la vara, del camino. Quite la vara del montaje de techo. Una vara de gota t?pica tiene un alfiler de chaveta que es quitado de un peque?o alfiler que corre aunque la vara y el montaje. Despu?s de quitar el alfiler de chaveta con las tenazas, deslice el montaje
Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
Check around the inner washer and underneath for any lost clothes or jammed objects. This can be anything from toys to shoes.
Considerations
If there are no objects, your washer parts may need to be cleaned or replaced. Call Kenmore at 800-4-MY-Home to talk to a service representative and find out about replacement parts.
Types
Along with "F51", error codes "F1" and "F50" could mean the same thing. Check for these error codes and follow the same procedure with your washer.
