My 125cc quad electric start suddenly stopped working, no click or anything completely dead. All the lights work fuse ok and it push starts no problem. Any help great full thanks.
SOURCE: I have bought 3 second-hand apache quad bikes. I
Did you fill the batteries and charge them first?
Another possibility is to check and see if all of the battery post cables are connected properly and check for corrossion.
SOURCE: Hi, I've got an International 560 tractor that
I think, if you look at the wiring from front to back you will most likly find one or more breaks in the insulation around the wires. This will cause a drain to the starter or a short to the system. Solution: track and replace all falty wires and ammeter
SOURCE: Throttle Problem
Hi
Your ESC is sensing an error. The error is either blade speed or a peripheral device - possibly servo or gyro. Sub the servos one by one. Check the blade tracking. Have you had any crashes lately? You should double check all the head assembly components.
