I have an indesit WIDL 102 ( washer dryer) with 2 lights flashing on it ( stain removal & easy iron) we have recently had a circuit board replaced (2mths ago at the back of the machine) & now the machine appears to be broken again & i am unable to even turn it on!!!
any advice would be gratefully received
thanks
Fiona
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
SOURCE: I have an Indesit WIDL 126 washer/dryer. When you
Check delay swith has not been operated also try resetting prog.. handbook shows you this,
SOURCE: Indesit Model WIDL 126 UK Problem: Shortly after
The model is a not a WA 125 - I couldn't fix the problem and have scrapped the machine.
