Dometic Rooftop RV Air Conditioner Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Furnace runs with heat but wont shut off propane furnace for rv
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on May 19, 2009
Anonymous
Expert
Level 2:
Answers
148
Questions
Helped
70521
Points
330
Check thermostat wire and thermostat itself
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Jun 21, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
12434
Points
54
Turn off the breaker
2012 Keystone RV Cougar X-Lite Series M-29 RBK. How to use the Furnace.
Question edited for clarity and full model details.
This is the manual and says the furnace instructions come depending on the maker, of the particular furnace.
https://keystone-rv-dealer-app.cdn.prismic.io/keystone-rv-dealer-app/5626704e-b671-464f-bd2f-9fb9ac611a73_2012+Keystone_owners_manual.pdf
The page is numbered 36 on the bottom left of the page, or 42 on the bar at the top.
Furnace The furnace is a propane gas appliance that requires 12 volt power to electronically light. New furnaces sometimes emit smoke and an odor during the first 5 - 10 minutes of initial use due to paint burning off the heating chamber. Do not mistake this for a malfunctioning furnace. Follow the suggestions in Chapter 2 regarding maintaining Indoor Air Quality if this occurs. Please refer to the manufacturer instructions supplied with the unit for care and operation. Please refer to the manufacturer instructions supplied with the unit for care and operation and/or
www.atwoodmobile.com or www.rvcomfort.com.
More here on the RV model
https://www.google.com/search?q=2012+keystone+rv+cougar+x-lite+series+m-29+rbk+furnace+instructions
2answers
Is the 2007 Montana 5th wheel furnace both propane and electric? If so how do I turn it to electric? Thanks Sue
no info generic answer if no paperwork notify an rv dealer--rv shop or online search using make and model of unit
Oct 06, 2018 • RVs
1helpful
Ruud Achiever 90 - too much heat. My gas furnace works with propane. When it kicks in, it produces too much heat so that the temperature in some very well ventilated rooms gets to 80F.
The heat is controlled by the room thermostat so may be that is not working . It may have a variable fan speed which could help you . but you would have to check that out with the makers .
2answers
Furnace not staying on
Could be thermostat or safety switch(es) in the furnace. Are you sure that the pilot is staying lit? Are you sure the main burner is lighting? Are you sure the forced draft blower is running, and the blower-detection "flapper" switch is working OK? Any of these safety devices will cause the gas supply valve to close if they are not "satisfied" in a few seconds after the thermostat calls for heat. They keep your RV safe!
Does it need propane to run the furnace or can it operate on electric alone. i have no owners manuel
Got here late...I am assuming this is for an RV. There are probably electric furnaces on some of the newer ones, however, an electric furnace would draw more power than most parks could handle, so the is answer is it probably needs to have propane. On your panel, or near your furnace, you will see a switch to tell the furnace to use propane or electric...if your furnace is capable of running on electricity.
Why did my RV rooftop a/c shut off when I unplugged the furnace?
Yes you do so it only runs on ac ,but when you said rooftop unit do you mean condenser or does unit have evaporator fan too
1helpful
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
4answers
6helpful
2answers
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
