How to replace the thermal switch, circuit board and motor on a sportsman 24 volt
My son's sportsman 800 will ride for about 10-15 minutes and then stop and if we wait, it will ride again...I need to know how to change out the thermal switch, circuit board and new motors repair kit...any tutorials anywhere or step by step?
this could either be the that one of the motors has died or the connecter on the bottom of the shifter switch has come disconnected, i'd probably check the shifter switch first, you'll have to take out the battery and then the black plastic panel by the battery this will give you access to where the shiter assembly is and then underneath the four wheeler you'll have to remove the two screws that hold the shifter assembly in and then verify that the two plugs are plugged into the bottom of the shifter assembley
The Peg Perego sportsman twin 800's are overheating the protection module. After it cools, it works again. They know about the problem and admitted it. Under warranty they just shipped me a new poly switch, a new mainboard and TWO new motors WITH gearboxes for free. (Mines 6 months old). Working on installing the parts now. It is NOT a battery problem but something to do with the 24 volt motors overloading the electrical system.
If you're talking about the low and high speed settings, it says there is a screw on the side of the pedal, it's on page 5 steps 51 and 52.
There have been shut off problems with this device that the customer service suggests is due to the battery. From what I read there are no override switches for this. I hope this helps.
The polaris 800's have a known issue with the thermal switches over heating, then they cut out after 10 minutes then after you wait about 5 minutes they come back on. Peg perego has a replacement kit with contains a new circuit board, thermals switches and two new 350 watt motors, I personally have replaced about 15 of them, its a pretty simple process
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
