SOURCE: Swisher lawnmower wont mow
Yes It would. The belt doesn't just wear it slackens also. It will probably turn the blades when not under load but as soon at it attempts to cut grass there is not enough grip.
Replace the belts first and it should be fine.
Regards
Marc
SOURCE: Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
SOURCE: Runs but cuts out when transmission is engaged
Check the deadman switch on the seat, I had the same problem with my John Deere and that's what it was.
SOURCE: I have a husqvarna ez4824 zero turn lawn mower.
either a weak seat switch or your electric clutch is going bad!
Testimonial: "Thank you very much for your input. You were right - it was the clutch."
SOURCE: When I engage the blades
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
