Kenmore 53642 / 53644 Side by Side Refrigerator Logo
A
Anonymous Posted on Dec 24, 2013
Kenmore model 106.53652300 has water on floor under the refrigerator
5 Related Answers
Anonymous
  • 92 Answers
  • Posted on Feb 10, 2008
SOURCE: refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Anonymous
  • 163 Answers
  • Posted on Jan 03, 2009
SOURCE: Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Anonymous
  • Posted on Apr 21, 2010
SOURCE: Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 22, 2010
SOURCE: I have a Kenmore side by side refrigerator, model
Sorry to read about your problem, I hope this helps you out.
i would turn off water to the unit, if its hooked up.see if it stops.. if not you lost the unit and it is melting
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Testimonial: "Worked like a charm, thank you for the timely response!"
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 27, 2010
SOURCE: My Kenmore Elite bottom freezer
rewrwer
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
In addition, your drain tube maybe clogged
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
1helpful
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Every couple of days lots of water runs out on the floor.
It sounds like the defrost drain is clogged up. On some models there is a removeable white pull out cup located in the center back wall at the top in the refrigerator section. It is connected to a tube on the back of the refrigertor.If that is blocked water will be in the bottom under the crisper drawers.
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
3helpful
2answers
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
1helpful
Water leaks on floor intermittenly from under middle
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. or your plastic tubing carrying water to the door assy may have a crack (dry rot)
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
