Toymax Viore  42 in. Plasma TV Logo
A
Anonymous Posted on Dec 23, 2013
LCD32VH56A WONT COME ON
1985 Winnebago RV wont start? Wont even crank?
I would check the battery voltage on the starter motor firstly.
2helpful
High pitched noise coming from back of Viore LC32VH56A. Not speaker related.
A refurbished set!
Its a coil or transformer that is not tightly mounted or is vibrating hard enough to make the sound, If this is a refurbished set that is why it was returned and exchanged-----
Two ways to fix---locate which board is bad and correct the problem with Hot glue on the individual part making the noise OR just replace that board.
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Sputtering then stopped running and wont turn over.
Wont turn over are you sure as wont start is differant than wont run
Wont start could be Battery/starter/or engine siezed.
Wont run is not the same,,, that could be lacking power /low on oil/water/ Fuel/or even engine lacking power like down on compression which is all the above plus more ....
So check it out let us know again. Ron
5answers
Top Toymax Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
