Refrigerators Logo
Posted on May 17, 2009
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
  • gdcroft May 18, 2009
    I like the Repairclinic.com site. Good tip. When I searched for model 106.54209300 I found the water filter part number is 4392922 for $38.80. Thanks for the help.
  • mendoluja Oct 06, 2009
    What is the part number for the water filter for a Kenmore refrigerator model 106.57072690?
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Answers
13
Questions
0
Helped
15186
Points
41
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
Ryerman
Level 1:
  • Contributor 25 Answers
  • Posted on May 17, 2009
Ryerman
Contributor
Level 1:
Answers
25
Questions
5
Helped
11228
Points
52
I found the part Number ( 451472 ) for the water filter at RepairClinic.com. the Price is $52.30.
Just type in Kenmore Coldspot Refrigerator and you'll find more info for your Frige.
2 Related Answers
Anonymous
  • Posted on Dec 22, 2009
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Anonymous
  • Posted on Dec 19, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Kenmore Coldspot gushes water when changing the filter.
There should be a shut off valve inside where the filter goes. When you remove the filter, it should slam shut.
https://www.google.com/search?q=Kenmore+Coldspot+gushes+water+when+changing+the+filter
1helpful
Question about size of Kenmore Coldspot Refrigerator
What Are Some Specifications of the Kenmore Coldspot ...
https://www.reference.com > World View
The Kenmore Coldspot 106 is a 20.7-cubic foot side-by-side refrigerator with a reverse osmosis Pur water filter, ice maker and digital controls.
1helpful
Kenmore coldspot 52582201- water filter part number
found it try here...
https://www.repairclinic.com/Shop-For-Parts/a4b6i183d605447/Model-10652582201-Kenmore-Refrigerator-Water-Filter-Parts
How to replace waterfilter on Kenmore coldspot model 106.56539400
Start by taking a look at the lower or back part of your refrigerator. A grille ought to be visible on both parts. There is a strong likelihood the water filter is inside if you observe the grille. Check the upper-right corner of the refrigerator if the grille on the back or lower portion is not visible.
https://www.usawaterquality.org/water-filter-on-a-kenmore-coldspot-refrigerator/
2answers
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
2answers
How often do I change the water filter
i cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
