Question about Master Flow Flow MF-1040 Cyclone High Volume Portable Air Compressor by Master
Master flow mf-1040 pressure guage inoperative
Guage won't work
    New Friend:
    Problem Solver:
  • 19 Answers
This is an air compressor not for fish, take the gauge off and see if there is a blockage. Run the compressor without the gauge and see if you feel air coming out of the hole where the gauge goes. If you do then the gauge is bad and it will need to be replaced. Masterflow should be a company online contact them for a replacement.
Posted on Feb 14, 2019
6ya staff
SOURCE:
Sears air compressor 919.167340 Need advice re: why tank pressure guage doesn't work when it's compressing air.
maybe you are reading the gauge wrong
the tank gauge and the regulator gauge will read the same but the gauge that reads when you adjust the regulator is the out line pressure to be n maintained during tool use
Aug 03, 2018 | Sears Air Tools & Compressors
I have a MASTER MH-75T-KFA kerosene forced air heater that runs a few seconds and shuts off. Air filter is clean and even does this with filter removed. Manual says fuel pressure should be 4.o psi. Guage...
I assume this has an electric blower and probably electric fuel pump? Does it have a fuel filter somewhere in the system? I'd try to return the fuel pressure adj. screw to factory setting. I'm guessing screw in decreased flow rate and out increases flow rate. If fuel pressure is measured on the burner side, then increasing flow rate should increase pressure. It's intuitively backwards. What does customer service say? Usually, they are helpful. They need to know there's a customer problem.
Feb 28, 2015 | Heating & Cooling
How to chck a fuel pump
check 12V at pump terminal when on/cranking
hear/feel pump operation (if external to tank)
if low pressure (carby) disconnect fuel line and observe flow. If high pressure (FI) connect fuel pressure guage and observe pressure. Check fuel filter while doing all this. Filters are the source of many problems that start people messing with fuel pumps.
Sep 14, 2014 | 1996 Chevrolet C1500
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Success
Jan 13, 2014 | Sanyo Xacti Cameras
Rinnai Q205s code bl65, not sensing flow, I think. Pump seems to be working. Is there any way to check the pump and sensor to isolate and hopefully fix the problem? I tried all the obvious things,, li
First of all measure the water pressure and the flow from the hot water side of the unit. IT could be a bad sensor and that is all. Let me know what the flow is and the pressure. YOu can use a gallon jug to measure the flow and a pressure guage is not that expensive at a hardware store.
Jun 04, 2013 | Rinnai 603000010 Replacement Flow Sensor
Fuel guage inop
is it digital or regular, if it is regular the float inside the tank may not be working
Dec 07, 2012 | 1988 Dodge Dakota
The oil pressure gage is reading zero and the oil is full. How can I tell if it is the gage or the oil pump?
It is quite possible that the Oil pressure guage is faulty or else with a zero reading of the oil pressure the engine would have packed out. So removing the valve door will confirm if there is oil flow and confirm the guage. You can also remove the line to the guage and connect the line to a bottle, when the engine starts up the oil pressure will be displayed with a good pressure spray.... but be careful not be spray it all over with a loose joint.
Nov 19, 2010 | 1987 Chevrolet Astro Cargo
Guages for a f350 ford truck .all 3 guages on the left side of instument panel are inop except for the oil pressure and its real low.
this is a common problem with the ford f-series the motors or the circuit board burned out on the back side. the cheapest and easyest fix is go to a local junk yard and get a used one this web site should help you locate a junk yard in your area that will have one... car-part.com
Jan 12, 2010 | 1992 Ford F150 SuperCab
I have 8000 miles on my Tucson check engine light came on at start up this morning...gas cap is tight...no problems?????
there are over 200 reasons for the check engine light to come on, the gas tank cap is just one of them, this light and the problem that turned it on are most likely covered under the federal emission warranty, contact the dealer. see trouble code list below for some of the probelems that cause a check enghine light.
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
Jun 16, 2009 | 2006 Hyundai Tucson
Master Flow Flow MF-1040 Cyclone High Volume Portable Air Compressor by Master Logo
238 people viewed this question
Top Master Flow Fish Experts
Karen J Gray
Karen J Gray
Fahr Quad
Are you a Master Flow Fish Expert? Answer questions, earn points and help others
