A High Limit Thermostat is what it says. If the temperature goes over limit, it cuts power to the element. The temperature itself is controlled by an electronic sensor called a thermistor, or a standard 'thermostat'.
it may vary depending on the model number. if you google "maidaid dishwasher xxxx manual" where xxxx is your model number you can find the manual that should tell you how to fix that issue.
If would help to know the model number of the dishwasher. But usually if pressing Cancel button does not get rid of it then there is a fault in the control module.
I just fixed my Maytag's bi-metal switch. I smacked it with the plastic end of a screwdriver. Problem solved. You may have venting issues in the dishwasher if it's continually overheating.
test the 1) fuse heat and replace it 2) test the board if there are voltage , if there are the board can be faulty or repair. 3) see your instruc. manual go to the section troubleshooting and see what is wrong. God bless you
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
The Thermostat has gone faulty. This can be replaced if you can get the parts. You need to contact, B&D indicate your problem, and exact, make and model, and inquire as to where you can purchase the parts, or if you do not wish to do it yourself, where to send it for repair.
Izula,
We have had two D2020 Black&Decker Irons that did exactly the same thing. I love the iron...but they have both lasted about 2 months before burning!
