I have a new device "Bose Stereo" and I want my speaker to recognize it.
SOURCE: car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
SOURCE: how to open the jbl radial micro speaker set?
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
SOURCE: Trying to find out if the amp for my 2003 Toyota
Metra Part# 70-8113
This is the only part you will require to retain factory amplifier when you switch to an aftermarket radio.
Best Buy does not use Metra Products.
They use cheap American International.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
SOURCE: How to connect new HDTV to old stereo JBL speakers via TX-860 Onk
Depends on the kind of plyg in you have at the back of your stereo...
most strreo has phone, aux, tuner ,e.t.c..
If yours has any of this good, just plug your red and white audio out cable in any of this element listed above, then go to the front of your stereo and activate the particular element you plug into and increase your volume.
You will definitely here a sound.
