SOURCE: tec patio II--convert from propane to NG
You'll need part #P2CKLP-NT Now all you have to do is find yourself a local TEC dealer
SOURCE: I need to convert my Weber Genesis Silver B grill
I would contact a propane distributor, They should be able to locate the part. I don't know where your at but the one in my area (Central Oregon is Ed Staub and Sons )
SOURCE: MY CHAR GRILLER 5050 WONT STAY LIT WITH NEW BOTTLE
More than likely, the regulator is locked up.
Turn of the propane tank, disconnect the hose from the tank, Wait five minutes and reconnect the hose. Turn the tank valve on VERY, VERY SLOWLY, until it's fully open. Light each burner individually (that's assuming you have more then one burner), the one furthest from the tank, first. Turn it to the highest flame height and then light the other burners using the same procedure.
If that solves your problem, remember whenever the tank is turned off, turn the tank valve on VERY, VERY SLOWLY.
If that didn't solve your problem, you need to remove and clean all the burners, as well as the venturi valves.
Hope this helped to solve your problem.
SOURCE: Hello, Just purchased the Masterbuilt
you need a regulator for natural gas and the tip for natural gas
the site you you are looking for is www.nextag.com
they have all the fittings you need to convert your smoker
i hope this helps you
bob
