SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at www.cpsc.gov and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
