Does it have a pre-engaged starter motor, that is the solenoid is fitted directly onto the starter. Check for voltage drop off across the two main cable connections on the solenoid. If faulty clean contacts or replace the solenoid.
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Sounds like the throttle control motor is not adjusting the engine speed to compensate for the load. Does the generator rev up to full speed if you turn OFF eco with NO load? Funny thing, I have one on my workbench that is doing pretty much the same thing. Runs on eco, revs up with eco off with no load, coughs, sputters and dies with a load in either mode. I will update with what I find when I figure it out in the next week or so. Have a new carb on order.
I swapped the carb and it made no difference. Still backfiring (rather dramatically) and won't stay running. I see on some other posts that Valve lash will cause this. It makes total sense as the exhaust valve gap actually tightens as the engine wears which would keep the exhaust valve slightly open when it ain't supposed to be allowing raw fuel to enter the muffler. With this one I can believe it as it has a ton of hours on it and I know they have never been adjusted. I will try to get a chance to do it over the weekend and update this post when I do.
I would guess that this uses both of the 15 amp breakers to make the 30 amp circuit. Try carefully measuring the voltage at the back of the 30 amp outlet after pulling it out. You may have a bad socket. look at how it's wired behind the panel too and see if there are wires from the other sockets to this one. If so, check all connections between them. If you still can't figure it out, try to get a picture of the panel and the wiring behind it and send it to [email protected]
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
First problem is caused by the new generator producing too high a frequency... 65 Hertz is above the inverter limit. Adjust the governor down to 60 or 61 Hertz. Breaker tripping may be due to excessive current draw from the Honda. Check the max AC input menu on the inverter. It might have been set lower to avoid overloading the original generator but if DC power was turned off at any time while you were changing generators, the inverter would have returned to it's default settings which may exceed the Honda's capacity.
