Hotpoint wmf740 will not spin but checked belt ok . Will drain water but not wash
After a heavy wash weekend spin stopped working. Checked belt is in place. it will not wash but will drain water. Runs through spin programme but clicks not followed by any movement on drum. Programme display seems fine. what next?
    New Friend:
  • 10 Answers
Motor Brushes have probably worn out
Posted on Dec 18, 2013
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: DRUM HAS STOPPED SPINNING
Well, I failed to find your product but found close and I've read the manual and can see no sign of anything being able to be presed that would stop motor operating in its wash cycles, I take it that you have totally drained/removed clothing and let machine get to normal start position, and done the standard disconnect from power, and plug it back in and test again and make sure no flashing lights are present and door is locking correctly
Possibility exists that your balance switch is faulty I'd look at that if not then Either motor is dead or control board is faulty
If you know your way around electricity then you could test if power is being supplied to motor.
As for the count losing 10 mins then thats pointing to control board fault (quite possible due to operations panel being operated)
Link to Manuals I read
http://www.boschappliances.com.au/content.asp?keyword=wfo&action=search&document_id=17&x=38&y=13
Posted on Nov 25, 2007
prem mathew
  • 1294 Answers
SOURCE: DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Anonymous
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
Anonymous
SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
ben fixit
  • 42 Answers
SOURCE: I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Posted on Mar 31, 2009
My hotpoint Aquarius wmf740 washer dial is just spinning is there an easy fix
yes
its in error mode
its trying to get back to where the error was last
drain the machine from the filter
power off the mains
hold in the power on button
and turn on the mains
it will reset
the machine does a simple self check when it turns on
so a faulty pump will cause this
usually its a faulty pump housing is leaking water
or blocked up
so the pump cant move
when you turn it on it spins the pump motor a few turns and detects its running
so you may need to remove the filter round cover screw
and its tray
and check the pump viens move
may be some hair clip or clothes wires stuck in it or a coin etc
it should go to then where it left off
i would at this point stop it with the button
move the selector to drain
and let it drain and end
or to short spin
if it spins aok and ends
then you can just go for it with a load
if it fails to short spin and drain something else is wrong
prob electronic
Dec 10, 2014 | Washing Machines
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
