Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Husqvarna Hydrostatic transmission is not delivering the consistent drive power that it once had. It is stopping going up small inclines. I have replaced the drive belt with no improvement. I am planning on checking the torque spring to see if that helps but I was wondering if there was some other adjustments that I can perform to hopefully rectify the issue. My tractor is a YTH 150
  • tcsmithsr May 16, 2009
    Thanks for the help
  • Shane Kennedy Jul 18, 2017
    I have a weird problem with one of these. The thrust bearings on the rear hydraulic motor had disintegrated, so I fitted a new one. Now,I have to disengage the drive on the forward box to go forwards, and the rear box to go backwards. It is as if I had reversed the hoses going forwards, but they are different lengths, so impossible to do that. Comments requested.
Anonymous
Level 1:
  • Contributor 11 Answers
  • Posted on Aug 02, 2009
Anonymous
Contributor
Level 1:
Answers
11
Questions
0
Helped
90310
Points
40
Try this - remove all the transmission oil from the transaxle and put in a heavyer oil - 50 wt.
see if your transaxle has a drain plug - if not you will need to remove the tranaxle from the lawn tractor. I had to try a ratchet strap to the rear of the tractor and lift it up until the wheels were free. I removed the brake linkage spring, the fwd/rev linkage, and wheels. Undo the axle bolts and two screws ofn the cross support bracket on the tranaxle mount. pull the vent fill plug on top of the transaxle and turn the transaxle upside down to drain all the oil from it into a pan. Refill with 50 wt. to the top and remount the transaxle back in place. Next you will need to bleed the system as follows:
1. Have the tractor on jack stands with rear wheel off the floor.
2. Start engine on low speed.
3. repeat open and closeing the bypass valve while alternating the forward and reverse pedals.
4. when wheels start to turn increase the engine speed.
5. repeat quick forward or reverse with panic braking stops until transaxle gets full responce.
6. remove jack stands and have tractor on the wheels.
7. recheck the oil level again.
I did this to mine and it will improve your tractor ability to climb hills like new. 30 wt oil is too light (good for brake in) when tractor was new and refilling it with 50 wt will work like new or better.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
88971
Points
26
If your Husqvarna hydrostatic transmission is like mine (2002 YTH1542XP), then it's sealed and you cannot change the oil. I'm currently investigation this issue as well because I've been having similar problems for years and I don't want to buy a whole new transmission.
  • Jim Thompson
    Jim Thompson Apr 15, 2016
    The idea that this transmission is sealed is a total lie. I had a leak in mine and all the oil leaked out and was told the same thing at the dealer and a new tractor was the only affordable option. I found that the transmission is made by Tuff Torque and they have all the parts available . I didn't need parts just oil. I found a vent on the unit under the battery compartment. It is a small black cap with a plug you can pull out. With a small funnel you can refill the transmission from here. The unit comes with 10W30 motor oil and I refilled it with Mobil 10W40 High Mileage. Tuff Torque recommends filling with 5W50 synthetic and you can buy that from them if you want. My solution worked wonders. High mileage motor oil contains a seal sweller and that cured my leak as well. Hope this helps.
  • Joe McClure
    Joe McClure May 10, 2018
    Put heavy grease on your drill and tap to hold the chips.
Anonymous
Level 2:
Sniper:
  • Expert 57 Answers
  • Posted on May 15, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
57
Questions
0
Helped
128094
Points
182
A common problem on mowers with hydrostatic transmissions is the pulley on top of the transmission. Most have splines which wear out. Also make sure fan on top of transmission is turning. Could be overheating.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
84321
Points
6
Husqvarna YTH 150 hydro transmission bypass will not disengage transmission
Kprime
Level 2:
Sergeant:
  • Husqvarna Expert 187 Answers
  • Posted on Oct 10, 2014
Kprime
Husqvarna Expert
Level 2:
Sergeant:
Answers
187
Questions
0
Helped
314398
Points
866
The Not Serviceable LIE
Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out a lie. All of the JD hydros are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the manufacturers fill them with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
  • Kprime
    Kprime Oct 11, 2014
    The YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams is here:http://www.m-and-d.com/Hydro-Gear_parts....
Joe Brady
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Jul 12, 2017
Joe Brady
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
84321
Points
7
I have a 2013 Husqvarna 22V42. I recently started to have this same issue, so I did some research and discovered this thread. Indeed my model has a Tufftorq transmission, and indeed the manual says the oil is not user serviceable. Indeed, however, I was able to pop off the small round black plug on the top of the transmission, and I used a hand pump to remove the old oil and put in 50W. Fired it back up and.... bummer. That wasn't my problem. Here's what it was. The brake pedal has a linkage to the transmission, such that when the brake pedal is pressed in, the linkage pulls a level on the transmission to disengage it. When the brake is released, the lever springs back and re-engages the transmission. My problem was: after a few seasons of mowing my dry native grass areas, enough dirt/dust/dry clippings got trapped behind the lever that it was not fully springing back into position when the brakes were released! Cleaned out the dirt. Works better than ever.
  • Jerritt Bronnenberg
    Jerritt Bronnenberg Nov 16, 2018
    Joe,
    Thanks so much for posting this! I had the same problem and after a couple of belt replacements and other searching, I was about to tear out the transmission. I saw your post and this was the exact issue. Its funny because I've been underneath this thing many times and you just can't see the grass/dirt piled up in that area so it goes unnoticed. Appreciate you taking the time to post this!
    -jerritt
Ken McDermed
Level 1:
New Friend:
Welcome Back:
  • Posted on Aug 23, 2018
Ken McDermed
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
84321
Points
6
I had this exact issue, but, the oil replacement wasn't the answer. I removed the transmission, pulled the plug on top, drained/replaced the oil, re-installed transmission - and same issue. My problem ended up being a very compacted build-up of grass/grime just in front of the lower dash area. This was preventing the forward/reverse pedal from going all the way down. It wasn't noticeable at all from a user perspective, as I suppose it had built up over time bit by bit. There was a TON of grass down there which isn't visible at all, and isn't easy to get to by hand. I ended up having to blast most of it out with a sprayer. It completely fixed the issue. Oh well... at least I know I have fresh oil in the trans, and things are all clean underneath. But, you might save yourself some trouble by first thoroughly checking this area out. Check not only the forward/reverse pedal side, but, the brake pedal side as well. If the brake doesn't fully disengage, it will affect the transmission pressure.
Terra McDaniel
Level 1:
New Friend:
  • Posted on Jun 11, 2016
Terra McDaniel
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
84321
Points
If it is losing power purge the transmission. Check the manual for instructions. We had this problem and purging it fixed the issue.
Kenan Civic
Level 1:
New Friend:
  • Posted on Mar 13, 2015
Kenan Civic
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
84321
Points
16
HOW MUCH DO YOU FILL IT?!
  • Kprime
    Kprime Mar 13, 2015
    The actual amount varies from tranny to tranny. However, on those I have serviced I just fill it till it comes up close to the top of the drain port. I stop 1/8th to 1/4" from overflowing. I doubt it would hurt it if you filled it up till it overflowed, and then plug it..
  • Anonymous Aug 19, 2018
    Geez dude. When asking for someone to provide you free information and free assistance, its probably not the best etiquette to use ALL UPPER-CASE, and an explanation mark at the end of your question - as if you're upset that their initial free write-up didn't help you enough.
2answers
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 • Garden
2answers
What would cause the mower to slow down and stop after 3 hrs mowing then after it cools down it moves what would cause it to do that ?
you have unseated valves the hotter it gets the less power you have until it stops to cool down need to take to shop and get vavle job about 100.00 dollars if you wait you will damage motor
2answers
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
I have a husqvarna rider 155, the transmission loses power after I have ben mowing for an hour
Hi, remove the battery and battery carrier, clean all grass and debris from the hydrostatic drive, cooling fins and fan. Your problem is most likely the hydrostatic drive over heating. Hope this helps, regards Phil.
1helpful
2answers
Riding mower accelerates extremely slow and seems to stop on inclines
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
1helpful
JUST PURCHASED A HUSQVARNA YTH2042XPT 2006 MODEL. AFER 30 MINUTES OF MOWING THE HYDROSTATIC DRIVE STARTED TO MAKE GRINDING NOISES AND IF KEPT DRIVING 10 MINUTES LATER THE MOWER LOST ALL POWER TO ITS...
Well if new I would take it back and if used I would be looking for another hydrostatic transmission.
These can be found on ebay, and there are some lawnmower recyling yards out there, you have to look for them. The price of a new transmission far exceeds the price of a used mower and is almost the price of a new mower.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
