Does not move from one cycle to the next. It will fill with water then just agitate until i realize it's been going an awful long time. Also, does not do a great job pumping the water out during spin cycle.
Does not move from one cycle to the next. It will fill with water then just agitate. Does not move from one cycle to the next. It will fill with water then just agitate.
You can't post conmments that contain an email address.
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Let me know how it goes. I'm still thinking and searching my repair manuals! Huuum Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start. Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on? Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
