SOURCE: agitator problems
sounds like you have some bad adgetator dogs
they are plastic and they sit inside the white adgetator . take that off and you will see four of them. usually you need to remove the fabric dispenser first to take the bolt out of the adgetator out.
SOURCE: kenmore washer shakes violently during spin cycle
I have a Kenmore 22990 top loading washer. it shakes violently and walks across the floor during the spin cycle. it started doing it about two weeks ago. moving clothes around inside the tub does not help much.
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating.
The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
Procedure:
SOURCE: I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Testimonial: "that does make sense. I'll try it out on a different cycle. The timer is going through its motions but I'll double check for any loose connections. "
