The sound at the bottom the drum and the problem on the spin cycle the sound very noise like jet running. the transmission or bearing issue? any body know the problem it.
Bearings have gone ,this happens when you over load the machine. cheaper to replace machine??????? but not to replace it with the same or sister companys machine
A Speed Queen top-load washer making a banging sound at the beginning of the cycle could be a sign of a few problems. You could examine the following:
Size of load: Check to see that you are not overfilling the washer. The water and clothes should be about 3/4 full in the washer. Overloading the washer can result in the drum becoming unbalanced and making banging sounds.
Leveling: Verify that the washer is level. If not, reposition the washer's feet until it is level. A washer that is out of balance can also make banging sounds.
Spring elements: Examine the suspension springs at the drum's top. The drum may slam against the washer's sides if one of them has broken or come loose.
Motor: The motor might be the source of the banging sound. The washer may vibrate and make banging sounds if the motor is loose or damaged.
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem. In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
