Upon starting and evry 25-30 minutes after I get a beeping sound, it beeps 5 times 5 times for a total of 25 beeps. What code is this? Dealership wants to put it on machine for 1 to 1 1/2 hours to run tests more like charge me $200 bucks then say we don't know.
SOURCE: slow beeping sound without warning light on 2002 Escape
IF you do not show any Warning Lights. You may have a bad bulb. Pull the Frame from around the Speedometer Dash and then unplug the cables and then Get a meter and and check continuity on the bulbs. They are pretty easy to twist & pull out. I had a warning sound the same as yours . Metered it out and found the Airbag is Bad. Wich is also attached to the Horn. Bad way to do things. Anyways try that.Circuspyro
SOURCE: Beeps coming from over by the glove box after turning engine off.
the beeps are an airbag trouble code, that code is for the following:
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
SOURCE: Beeping
When you turn key on check if airbag light on instrument cluster comes on. 5 beeps is the tone to let you know your airbag light in instrument cluster is inop..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/terry_db4da071b7da3ac1
SOURCE: 1996 Ford Taurus Making a beeping sound
Mine beeps like that as well if I don't put my seat belt on. The seat belt light comes on for about a minute then shuts off and a few seconds later it starts beeping without any lights coming on. This may not be what your problem is but I was wondering why mine did the same thing and I figured out if I didn't have my seatbelt on that's when it would beep like that. The seat belt light had already shut off and wasn't blinking or anything so I didn't realize that's what it was right away.
SOURCE: 5 beeps 5 times when i start the truck
does the airbag light come on when you start vehicle? If the lamp is out it will give an audible beep.
Testimonial: "well i dont see the airbag light when i start the truck ,how would i replace the light? and would this stop the beep even if the airbag light was on"
