SOURCE: I need to replace the
To replace thermostat inside of the cooler back panel needs to be removed.That gives you more room, to remove the thermostat. You have 2 screws on the bottom of the evaporator that holds the thermostat sensor in place. Then the thermostat sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.The thermostat should be clamped onto the bottom of evaporator plate. --------- this will help.thanks.Helpmech.
