How bad?
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
SOURCE: washing machine fault
hi mine flashes when you are aloud to open the door so i cant see this as been part of you problem sorry cant help more
SOURCE: indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
