Hi art altising, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? make and model?Hi art altising, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? make and model?
You can't post conmments that contain an email address.
? 11:04 www.youtube.com/watch?v=er-f7DlUJbk Sep 16, 2013 - Uploaded by Peter Finn
How to fix error in power door locks or central lock system Toyota ... Years 1999 to 2007. ... Remove all ...
Drain pump triac failure
This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
Check pressure switch contacts and connectors
Failure of the pressure switch or level sensor can also give rise to this fault code
Run test program
If failure persists after test and verification of pressure switch, replace main controller
You have a clog some where
F26
Run test program
DOOR SWITCH ERROR If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Door not opened during 3 consecutive cycles. 1. Open and close the door. 2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked. 1. Push the door and check if it is completely closed. 2. Verify CCU operation by running a Diagnostic Test or any cycle.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing the Service History Mode: Execute this procedure with an empty drum. All of the steps below must be done in sequence in order to reach the Diagnostic Test. This executes the automatic test but does not show the error history. Close the door. Push POWER. Select the CLEAN WASHER cycle. Press EXTRA RINSE four times within 5 seconds. Press EXTRA RINSE to advance to the next step of the test procedure. If the starting procedure fails, push PAUSE/CANCEL, then repeat the starting procedure.
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
