Question about Dometic Rooftop RV Air Conditioner
RV heater fan started running even though the furnace is set off.
Yesterday it was off , this morning my wife went into the trailer and found the furnace fan going but no heat since the propane is still off. she checked the thermostate and it was set to "off". She couldn't turn it off. Pulled the fuse to shut it off.
Any ideas???
    Loyalty:
    Visited the website for 30 consecutive days.
  • 572 Answers
If thermostat is set for fan ON then fan would run all the time ,otherwise you might have a stuck relay
Posted on Feb 22, 2018
    Sergeant:
  • 212 Answers
Contact Dometic customer services, they can advise you further...
I hope this helps....
    New Friend:
  • 21 Answers
Thanks and keep up the good work!
Run 3
    Top Expert:
  • Dometic Master
  • 10,764 Answers
Was fan on auto?
Posted on Feb 06, 2018
  • 332 Answers
Replace the thermostat it ain't no good no more
Posted on Mar 06, 2010
Anonymous
SOURCE:
2014 Heartland Fairfield 405fl (extendend stay) Suburban SF42-Q furnace Does anybody know of any Mobile RV Mechanics in San Jose Ca (Bay Area-South)? Our furnace blower fan went whacky and broke the cage....
Go to Bryantrv.com and click on the Service Manuals link. It sounds like he missed a wire hooking it back up. There are usually 3 wires, red for hot, connected to the furnace and also a small blue wire with a red stripe, another small blue wire connected to varying colors but comes from the thermostat and a ground, usually yellow. There is a relay on the fan side of the furnace and a thermal safety on the back side, under the burner. The fan gets it's power from this relay and the furnace will not run until the fan is turning. It's common for the relay to go bad but I've only had to replace on thermal fuse in the last 12 years.
Mar 16, 2015 | Heating & Cooling
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Trane xv95 converted to propane is on system lockout
worth checking over heat temp sensors (klixon ) sensors can cause heater to go into a cool down purge Through an open circuit heat exchanger (Klixon ) temp sensor Ive seen before good luck
Nov 25, 2017 | Honeywell Electronic Programmable...
Coleman furnace runs a lot
You did not indicate the year or size of the mobile home, but, having lived in several in cold Michigan, here are some things.
Be sure all the windows are well sealed.
At first, I used to put a strong clear plastic sheet over the insides, and tape these in place.
Later, I bought foam insulation board at a lumber yard and cut pieces to fin the window openings, and taped them in.
When it is really cold, feel the walls, the floor, and the ceiling.
If you find cold to the touch, you are losing heat there.
If your floors are cold, put insulating panels and skirting around the bottom of the trailer.
If your extreme cold lasts for months, some people consider putting a small electric heater under the trailer that is temperature controlled.
Some people do a "roof-over" by setting poles or posts alongside the trailer and adding an additional roof above the trailer.
That step would enable you to add insulation above the top if your ceiling is cold.
God bless your efforts.
Oct 27, 2017 | Coleman Propane Forced Air Heater...
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
437 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Thomas F. Schneider
John Tripp
John Tripp
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
