gmail.com Logo
A
Anonymous Posted on Dec 12, 2013
[email protected] is on older server i cannot access why?
johnshelp
Level 2:
Sergeant:
Champion:
  • Expert 204 Answers
  • Posted on Feb 01, 2015
johnshelp
Expert
Level 2:
Sergeant:
Champion:
Answers
204
Questions
0
Helped
30355
Points
602
To get to your preferred gmail account, you have to sign out of the one you don't want.
1. When you are in gmail, click on the account icon in the top right corner.
2. Click on "Sign Out".
3. On the "Sign Out" page, click on "Sign in with a different account".
4. Here you should be able to access the gmail account you prefer.
Hope this helps.
John
Hd bigpond as server .have change provider who does not supply email.does gmail need google only s a erver for my computer
Google has its own mail server. If you decide to create an email address with Google, your mail will be managed there. You can access thru the gmail web site for mail, or use an app (Outlook, Thunderbird, etc.) to view your mail
I am using GMAIL with Outlook Express but my outgoing mail does not go out as all my parameters is set properly accordingly
Gmail will no longer accept 'pop' remote access to accounts. You have to logon to the account via your browser and read your mail.
Jun 25, 2014 • gmail.com
1helpful
Yahoo email doesn't reach gmail inbox
There is a high chance that Google is not actually receiving the emails concerned. By any chance are some of them automatically generated and not actually sent by a person directly using Yahoo (i.e. a Yahoo web page or a Yahoo SMTP server) ? My mind is suspicious that the MX is set up wrong at the transmitting server and that server is therefore not Yahoo's own server.
Login to [email protected]
Transfer Email to a Different Server
Each of the free-email providers has its own server on which to store the emails in its system. Gmail from Google, Hotmail from Microsoft, Yahoo! mail from Yahoo! and the rest all run their own servers, and one account from one server cannot go into another from a different server.
So if you've switched from Yahoo! to Gmail and want to get all the emails stored in the Yahoo! server over to the Google server, you have to transfer that email data.
Luckily, since the services are free, transferring the email is also free.
Log into your email account in the server that you are looking to transfer to.
So if you are transferring from Yahoo! to Gmail, log into your Gmail account.
Click on the "Settings" or "Option" button for your email address and then click the "Accounts" or "Accounts and Imports" button to look at the accounts.
Click on the "Import from another account" or "Add account" buttons and then type in the log-in information for the account that you want to transfer the emails from.
In the example given, you are transferring from Yahoo! to Gmail so you will need to type in your Yahoo! log-in information.
Wait for the server to transfer all of the contacts and email from the old server (Yahoo!) to the new server (Gmail).
http://www.labnol.org/internet/email/move-mails-across-email-accounts/8419/
Get My Yahoo Mail Moved to My Gmail Account
Nearly everyone has multiple email accounts for different purposes, and occasionally you may need to transmit information from one account to another.
Gmail makes it easy to import data from other Internet email providers via the TrueSwitch email migration service.
You can use TrueSwitch to migrate all of your Yahoo email data without even leaving the Gmail program window.
Navigate to the Gmail website and log in to your Gmail account.
Click the "Tools" icon in the upper right corner of the program window and click "Mail settings" in the drop-down menu.
Click the "Accounts and Import" tab in the settings window.
Click the "Import mail and contacts" button to start the mail import wizard.
Type your Yahoo email account address in the text field and click the "Continue" button.
Type your Yahoo email account password in the text field and click the "Continue" button.
Check the box next to each type of data that you want to import from your Yahoo email account. You can choose to import contacts, mail, and new mail that you receive within 30 days.
You can also specify a label that you want attached to all imported mail. Click the "Start Import" button.
The TrueSwitch service will begin importing the desired data.
It may take between several hours and two days for all of your data to be imported from your Yahoo account.
Gmail access
In the e-mail account settings you should use the following:
IMAP server address: imap.gmail.com
user name: exactly what you use for logging in gmail on a computer, such as [email protected]
password: your password
IMAP port: 993 (This is important. Otherwise it will not work)
encryption/security: TLS/SSL
In order to send mail, you also need to give the program these SMTP settings:
SMTP server address: smtp.gmail.com
port: 465 (once again, an important number)
security: TLS/SSL
I hope this helps.
How to configer email address in lotus notes
From what provider are you trying to configure email?If its gmail,
1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
Account document for Incoming Gmail:
The Basics tab
a. Account name: Can be anything (I chose In Gmail)
b. Account server: pop.gmail.com
c. Login Name: Your gmail email address (complete with the @gmail.com)
d. Password: Your password
e. Protocol: POP
f. SSL: Enabled
g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
Advanced Tab: This is the most important tab.
a. Port Number: 995
b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
d. Send SSL certificates when asked (outbound connections only): No.
e. Verify account server name with remote server's certificate: Disabled
f. SSL protocol version: V3.0 with V2.0 handshake
3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
Account document for Outgoing Gmail:
The Basics Tab
a. Account Name: Can be anything. I chose Out Gmail
b. Account server name: smtp.gmail.com
e. Protocol: SMTP
f. SSL: Enabled
a. Port Number: 587 or 465 (Both are SSL port and both work)
4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
5. In the same local Address Book, choose New --> Location
Basics Tab:
a. Location Type: Local Area Network
b. Location Name: Can be anything (I chose Gmail)
c. Internet Mail Address: Your gmail email address
Leave the rest as it is.
Servers Tab:
a. Home/Mail server: pop.gmail.com
Ports tab: No changes (ensure TCPIP is checked)
Mail Tab (Most important):
a. Mail file location: Local
b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
d. Send Outgoing mail: directly to Internet
Leave the rest of the fields as it is.
6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
17helpful
5answers
What iis the outgoing/incoming server for gmail?
Google GMail Settings
The Google GMail service offers email client access for retrieving and sending emails through your Gmail account. However, for security reasons, GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
    Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)
    Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
2answers
How to transport aol favorites to gmail
I presume that you mean contacts export from AOL, to Gmail, correct?
I am not on AOL any longer, so I cannot find out if they have an export function.
Gmail, however does have an IMPORT function.
Log in to your gmail account.
>>Top right, several to the left select settings
>> 2nd tab, accounts and imports..
What you need is the first option...
Also are you planning to use the online mailbox of Gmail, or a local client, like Outlook, Windows Mail, or Incredimail>>>>? If so you must turn on POP access, or you will not be able to connect... This is the 5th tab of the page you were last on (listed above, in settings).
Lastly if you are using a local client, often you cannot use the GMAIL outgoing mail server. Because of spam, internet service providers commonly require all mail going out to go through THEIR server....
Not a problem, if you use inline mailbox of gmail. because you are sending from there....
Doc
2helpful
Email account setting
hi,
you have to select imap4 as the connection type, not pop3.
incoming mail server ---- imap.gmail.com
outgoing mail server----smtp.gmail.com
these are the setting that are needed to access gmail on your mobile
rate me if it solves your problem.
Top gmail.com Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Stan Ford
Are you a gmail.com Computer and Internet Expert? Answer questions, earn points and help others
