When try to reset eooooo1, there is error e719
SOURCE: canon ir c 3200
It is a fuser heat error. Try to reset the machine from the error code. If problem persists you have the check the fuser for damage. Could be a thermister, thermoswitch, or faulty heaters. To clear error, service more function/clear/error/ok/ exit service mode and cycle power.
SOURCE: canon irc 3200 error code E000001-004
Want to print a Microsoft Office Publisher document to Canon iR C3200 and it gives'
me this message: Cannot continue to print as the disk is full. I have plenty of room on
my drive and so does the copier. Please advise
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
