-Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD.
- When you see this message press any key.
-In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
-Select the operating system you wish to fix, and then enter the administrator password.
-Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
-You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
-Type exit to reboot the computer.
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors. Hope that helps.
hi, right you need to boot up using your windows disk, change the boot order so it picks your DVD drive first, now select repair once windows starts up.
"Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll. Please re-install a copy of the above file."
"<Winnt_root>\System32\Hal.dll missing or corrupt: Please re-install a copy of the above file."
"Cannot find \Windows\System32\hal.dll"
"Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears.
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Please let me know you have any further questions or concerns.
Thanks.
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
