Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Mouse destruction! All Pro Multi fuel forced Air Heater 200T, has mouse damage in the control board area. I need a circuit board diagram to be able to replace wiring. Help!!
    Habit-Forming:
  • 188 Answers
2 Suggested Answers
tbugger
Jerry Magee
  • 232 Answers
SOURCE: All-Pro forced air heater multi-fuel
What does this part do and what is the model of your All-Pro?
Posted on Jul 16, 2008
Anonymous
  • 540 Answers
SOURCE: While cleaning my heater, I accidentally pulled 3
Look on the electrical panel that you removed to get to the electrical wires.
Posted on Dec 18, 2009
It keeps shutting on and off. i have a all pro 200T model.
admin691,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix the unit and where to get the parts, special tools and more information.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Why does a allpro 200t keep flamming out??????
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 09, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Where can I find a manual for an All-pro 200T
You can go to www.desaparts.com to find the owners manual.
Here is a link directly to the manual.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/109891-01B/109891-01B.pdf
Oct 06, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
All pro 200t
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
Jan 10, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All Pro 200t Will not ignite
John- the ignitor does not stay on for the duration of the running time. It only stays on for the first 5 seconds. This is long enough for the flame to ignite and perpetuate itself, assuming the fuel delivery system is up-to-par. The photocell monitors the flame color and if the flame becomes off-color then the photocell tells the control board to shut the unit down. Naturally, too rich or too lean affects flame color.
Now, I'm confused by your description "the heater cycles 3 times". Tell me more.
I'm glad to see that you checked the pump pressure. Have you used soapy water to check for air leaks all the way to the nozzle? A leak in the airline, fuel line, or a crack in the nozzle adapter will cause no fuel delivery, or reduced fuel delivery as well as reduced atomization of the fuel - all of which can cause a lack of combustion. A restricted fuel filter will cause starvation.
Eliminate all possibilities of a fuel delivery problem before you start blaming electronics because there is not much way to test the board or the photocell successfully without DESA's diagnostic tool. Unfortunately, replacement of the componants is cheaper than the tool.
Dec 17, 2008 | Desa International RH125AT Utility Heater
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Jul 09, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
103 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
